I have just switched to PhoenixFD 3.00.01 from official 2.2.
I am doing a simple smoke simulation. It all works fine at the given sim resolution, the smoke is thick and works just fine.
But when I change the sim resolution either up or down, it won`t simulate. Or rather, it seems to be working since it takes some time on each frame, but nothin shows up in the render window, and the .aur-files are empty.
It also doesn`t help to change the resolution, save and reopen the file. It still won`t work as it should. But if I change the resolution back to the original, it will simulate fine again.
This was never an issue in 2.2, so it seems like a bug to me. Do you have a solution?
